1. RuRu55's Avatar
    My edge 6s plus isn't turning on. Its completely dead, won't charge, etc....
    I really need the photos that are on it. They are not backed up anywhere.
    Is there anyway I can recover the photos??
    Please help!
    Thank you!
    08-04-2017 01:20 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! You've already tried pressing and holding Power for at least 15-20 seconds, right? If the phone is completely dead, then you could try bringing it to a repair shop and getting the battery replaced. If that doesn't help, then it's probably a faulty motherboard, in which case the data is lost.
    In the future, take advantage of Google Photos auto backup: https://support.google.com/photos/an...DAndroid&hl=en
    08-04-2017 01:09 PM
  1. Replies: 2
    Last Post: 08-07-2017, 12:22 PM
  2. In advance settings i can not remove websites list
    Last Post: 08-04-2017, 01:10 PM
  3. Replies: 1
  4. My Droid Turbo has no cell service with my Metro PCS SIM card
    Last Post: 08-04-2017, 08:29 AM
