1. masterx1234's Avatar
    I'm about to give up on this phone and just sell it. I have a galaxy s6 edge plus and i replaced it with 3 batteries so far and every one of them gives me random and horrible battery life, i did some calibrating by letting it die to 0% and then charge to 100% overnight then repeated 4 times. and still no good. I barely can use my phone normally for half the day even with power save mode on. Anyone know whats going on here? replacing the battery was hard enough taking the phone apart and now this...
    09-17-2017 11:33 AM
  2. belodion's Avatar
    First, what do your battery stats show as using the charge?
    09-17-2017 12:21 PM
  3. masterx1234's Avatar
    Thats weird there was no reply button earlier but there is now for some reason, but anyways, The battery stats just show a pretty much stead decline when benchmarking the same app. Also its pretty much random.
    09-17-2017 04:34 PM
  4. belodion's Avatar
    Okay, but what apps are listed as having used the charge?
    09-17-2017 04:41 PM
  5. masterx1234's Avatar
    Screen, phone idle, android OS, android system and audioserver. this is on a fresh factory reset, only app i tested was youtube for battery drain, played the same 10 hour long video at the same brightness and power save mode on medium. results are just random after each charge.
    09-17-2017 09:24 PM
  6. belodion's Avatar
    Assuming that you have at least a reasonably good cell signal, and that the battery performance is much the same when using wifi, I'm guessing that there may be a fault with the phone, but I'll move the thread to the S6 Edge Plus forum for comments from other users.
    09-18-2017 06:03 AM
  7. Rukbat's Avatar
    What you did - charge/discharge 4 times (usually 3 times is enough) isn't recalibrating anything, it's conditioning the battery. You do that to a new phone (or battery) in case the battery has been sitting on a shelf for months.
    To recalibrate, you can use Battery Calibration (Root), but the phone has to be rooted to recalibrate the battery (the app has to change the system file that holds the voltage of the fully charged battery).
    09-18-2017 04:16 PM
  8. masterx1234's Avatar
    Well i figured out the issue! I decided to take the circuitboard out and inspect the connection of the daughterboard was so loose the connector just fell right off when moving the board, i snapped it back on there securely and now im getting the correct battery life! so all the issues was just a short between the connectors all this time, I am so relieved. thank you guys for the help.
    09-18-2017 10:01 PM
  1. What's going on with my battery?
    By onnad in forum LG V10
    Last Post: 09-28-2017, 08:52 PM
  2. Battery Performance Tips
    By kareem_ruhi in forum Samsung Galaxy Note 8
    Last Post: 09-27-2017, 07:47 PM
  3. Samsung Tablet in chinese and no google apps after factory reset
    By Poodgeheid in forum General Help and How To
    Last Post: 09-18-2017, 05:36 PM
  4. Battery drain and bluetooth connection issues
    By shelly25 in forum Samsung Galaxy S7 edge
    Last Post: 09-17-2017, 10:57 PM
  5. Apps not working like games and navigator
    By Sibastian dfx in forum Ask a Question
    Last Post: 09-17-2017, 12:26 PM
