    My phone makes a random tritone sound several times a day. It started a month and half ago and I've turned off notifications on all my apps. I've also reset to factory settings. I also downloaded an app that tells you what notifications you received but have not been able to determine the source. I'd like to know how to determine the source of the sound.
    Thanks
    01-13-2019 06:43 AM
  2. belodion's Avatar
    Is it a carrier-tied phone? That may be relevant.
    01-13-2019 08:17 AM
  3. Atts6's Avatar
    Yes it's carrier tied. I purchased the phone from att.
    01-13-2019 10:40 AM
  4. Atts6's Avatar
    Hi do you have additional suggestions as its carrier tied. Also not a roaming issue.
    01-15-2019 03:32 PM
  5. B. Diddy's Avatar
    Welcome to Android Central! Does it also happen if you turn off NFC?
    01-15-2019 05:23 PM
  6. Atts6's Avatar
    NFC is definitely off as is samsung pay. I just turned the phone on in safemode today and it hasn't made a sound. I'll monitor it for the next day or two and if the sounds stop then at least I know it's a third party app.
    01-15-2019 10:20 PM
  1. Notification badges on Huawei P20
    By selderij in forum Huawei P20 & P20 Pro
    Last Post: 03-22-2019, 04:33 AM
  2. Archive several messages on Android
    Last Post: 01-14-2019, 03:56 PM
  3. Alcatel pop 4 plus (5056e)
    By AKINKUNMI FADEYI in forum Ask a Question
    Last Post: 01-14-2019, 02:04 PM
  4. Notification badges on Huawei P20
    By selderij in forum Ask a Question
    Last Post: 01-13-2019, 03:49 AM
  5. Countdown on lockscreen I did not make.
    By jules317 in forum Ask a Question
    Last Post: 01-13-2019, 03:02 AM
