A
AC Question
hi guys. i bought an s6 edge(SM-G925F),lollipop, from a guy like a week ago. and its rooted.so i want to update it to marshmallow and to get that i have to unroot it. i tried to do it using odin 3.10.6 and i downloaded the stock firmware two times from two different websites. odin failed both times.with the first firmware, it gave me an open serial com port error and with the second firmware,it gave me a NAND write start fail. what should i do?
1-should i flash marshmallow?will it unroot my s6 edge?
2-should i just try with odin(it tried like 5 times)?
3-is there any way i can unroot it with supersu?(it was rooted through odin)
i tried smartswitch too but it just doesnt show me the updates.
please help!!
i got to know of the odin method from this site: androidrootz
btw i am from pakistan and can you tell me if my sims would work in the like usa or uk firmware. would installing some else country firmware fix the problem?
thanks
please help!!
thanks
