    so I'm using Samsung s6 Edge and rooted it with using SuperSU app. however i think the rooting was not successful because it has affected many part of my phone.
    when i boot my phone it shows " kernel is not Seanoid Enforcing"
    first problem i cannot update my OS.
    my PC can't access my phone (only charges, even in debugging mode). mind you i have updated SAMSUNG driver on my PC
    hence, there is no way to flash my phone back to original firmware through Odin or Smart switch app
    BUT MY PC CAN'T JUST SEE MY PHONE
    08-08-2018 06:11 AM
  2. B. Diddy's Avatar
    I moved this to the S6 edge Rooting forum for more specific traffic.
    08-09-2018 02:02 PM
  3. Grantorkush's Avatar
    If you can't repair it and its in good physical condition but useless I'll buy it for parts to fix my s6 edge.
    Thanks Grant [phone number redacted by Mod]
    12-22-2018 11:25 PM
  4. B. Diddy's Avatar
    Mod note: Please don't include any personal info in your posts, for your own privacy. you can always send a Private Message to another member if you're interested in a transaction.
    12-23-2018 01:33 AM
  5. Rukbat's Avatar
    Bit of an old post but
    1. If the phone is rooted, SEAndroid Enforcing will be off.
    2. You can't update a rooted phone. You'll have to flash the stock ROM back, update, then find something to root the new ROM. (SuperSU is just a little app that keeps track of which apps you've given permission to access su. su is actually what's giving you root. But once you update to another version, you can't install su because th phone isn't rooted, and the SuperSU zip for the current version probably won't root the next version. (And it could brick it, so don't try.)
    Grantorkush, great offer - do you also give away free ice in the winter at the North Pole?
    12-27-2018 11:55 AM
  1. I want to go straight to my new message
    By Troy Adam in forum Ask a Question
    Last Post: 08-10-2018, 12:57 PM
  2. My Huawei P9 lite keypad doesn't want to pop-up.
    Last Post: 08-09-2018, 02:11 PM
  3. Network mode is not working in my Samsung J3 2016
    By Dua Khalid in forum General Help and How To
    Last Post: 08-09-2018, 02:06 PM
  4. Samsung galaxys8+ all of the sudden won’t charge or tun on
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 08-08-2018, 12:21 PM
  5. Samsung galaxys8+ all of the sudden won’t charge or tun on
    Last Post: 08-08-2018, 05:14 AM
