1. ccypruss000's Avatar
    Good morning I have the Samsung Galaxy S6 Edge which I want to pass the European Lollipop ROM over. Now has the European Nougat. Should I first unlock OEM and USB stick errors from programming options? Should I edit some files?
    ROM Lollipop Europe: 5.1.1 https://www.sammobile.com/firmwares/...XU3COI9/57947/
    5.0.2 https://www.sammobile.com/firmwares/...XU1AOE3/47454/
    Please Help !!!!
    12-27-2018 03:24 AM
  2. Rukbat's Avatar
    You don't edit or unlock anything. See [Samsung] How to flash Stock ROM via ODIN for instructions.
    12-27-2018 11:49 AM
  1. how to end a call on a galaxy 46mm
    By Android Central Question in forum Samsung Galaxy Watch
    Last Post: 12-28-2018, 12:52 AM
  2. White lines image clipboard Samsung s9
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 12-27-2018, 11:36 AM
  3. I want to delete latest update file
    Last Post: 12-27-2018, 06:14 AM
  4. Upgrade Galaxy Tab3 GT-P5210 to newer version
    Last Post: 12-27-2018, 05:02 AM
