    I try to download and install ping pong root but it says not installed and it keeps the app away what is a way to get that the stop so it will accept it
    05-20-2019 09:05 PM
  2. mustang7757's Avatar
    You need to check XDA forum for that
    05-20-2019 09:10 PM
  3. B. Diddy's Avatar
    I moved this to the S6 edge Rooting/ROMs forum for more specific traffic.
    05-21-2019 02:05 AM
  1. How do you import Google Earth 'My Places' from pc to android?
    By asystole420 in forum General Help and How To
    Last Post: 06-22-2019, 05:54 PM
  2. Why can't I delete files from SD card?
    By Chi20cho in forum Ask a Question
    Last Post: 06-01-2019, 03:04 PM
  3. My emails won't sync on mobile data.
    Last Post: 05-21-2019, 02:07 AM
  4. Replies: 0
    Last Post: 05-20-2019, 02:34 PM
  5. How to turn off the mobile ultra power save mode using computer screen?
    Last Post: 05-20-2019, 12:01 PM
