    I have the China variant of S6 Edge. Which probably has the exact same specs as the other variants. I found an interesting custom rom that was originally for Note 8, ported for all the variants of S6 Edge EXCEPT MINE, THE CHINA ONE So I was able to install the port successfully. The phone also boots properly. But once the lock/home screen appears, I can't do anything because the touch doesn't work. My question is, Is there any tweak I can do to the rom.zip file so that I can make the touch work on my device. Like take some attribute from the stock rom and modify it on the custom one.
    10-09-2019 12:07 PM
  2. mustang7757's Avatar
    Hi, welcome to Android Forums
    I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
    I'll provide a link to register, please come back to your post so we can further assist you .https://forums.androidcentral.com/sh...d.php?t=409154
    10-09-2019 12:17 PM
  3. mustang7757's Avatar
    Once you start flashing different ROMs on the phone you basically throw out any help we can give , as we help more with stock ROM , better place to ask would be XDA Forums and the developer of that ROM.
    10-09-2019 12:24 PM
  4. B. Diddy's Avatar
    I moved this to the S6 edge Rooting/ROMs forum for more specific traffic.
    10-09-2019 12:27 PM
  5. Galactic Zoo's Avatar
    Go back to wherever you found the ROM and see why this wasn't done by the developer. We can't comment on other people's work when you haven't provided any information. As mentioned above XDA forums is your best bet
    10-09-2019 12:37 PM
  6. Rukbat's Avatar
    If you can't decompile the ROM, no, you can't change anything. (And if you could, you probably wouldn't be asking.)
    See if you can still get into Download mode and flash the stock ROM. Then contact the developer.
    10-09-2019 05:08 PM
  1. my honor play not tuuring on after its screen goes off automatically plz help
    Last Post: 10-10-2019, 12:08 PM
  2. Hotspot on my phone not working
    Last Post: 10-10-2019, 12:02 PM
  3. Samsung S8 - Bluetooth media audio works but call audio doesn't work
    Last Post: 10-10-2019, 11:10 AM
  4. Download Manager not working
    By belphazhor in forum Ask a Question
    Last Post: 10-09-2019, 04:59 PM
  5. My cherrymobile stuck on turning on
    Last Post: 10-09-2019, 10:58 AM
