Another tradition of AC is the screenshots thread. Got a cool homescreen or something else you want to share? This is the place...
Keeping it simple...
Using Nova Launcher, with Zooper Widgets, Nox icon pack, and Planets Pack live wallpaper.
Does installing a launcher kill the swipe in from the side for quick contacts or the edge clock and color notifications?
Home Screen - Nova Launcher
http://i.imgur.com/4LxBl10.png?1 http://i.imgur.com/k4d0NA1.gif
Which Planets Pack LWP is that. there is a few out there and none show that planet. Who is the dev. Thanks in advance
Does this (or any live wallpaper in general) use up more battery power?
Its Kairo XP Widgets which is an expansion pack for HD Widgets. There are many choices once you get in there. This one is called: Header w/ Indicators. You can choose which indicators that you want. I changed my wallpaper to black so I could see the side bars better and made the Widget background to have no background color. I think it looks cleaner.
