Its Kairo XP Widgets which is an expansion pack for HD Widgets. There are many choices once you get in there. This one is called: Header w/ Indicators. You can choose which indicators that you want. I changed my wallpaper to black so I could see the side bars better and made the Widget background to have no background color. I think it looks cleaner.
Does this (or any live wallpaper in general) use up more battery power?
After using them for years, I've observed live wallpapers to typically consume 1% or less of battery power. The one I'm currently using has never even showed up on my battery usage stats. I wouldn't worry about it.
I love the clean look of just a simple Black background. Should help with battery drain too!
I am using the Heeda theme with different wallpaper. The wallpaper that comes with the Heeda theme is very light and does not provide adequate contrast for text and widgets.
