Happy to be shot down here, but I appear to be one of the few people who does not like the edge.
I was seriously considering purchasing one (as my S4 is almost out of contract), and the reviews are all excellent, and basically directing people away from the standard S6.
I got to hold an edge last week, and was not impressed,
Have I got it totally wrong or is the edge just for show and not much use in reality. What are people views ?
Andrew
- The actual use of the edge appears to be limited to contact details and maybe a clock.
- Whilst there is an API for the edge function, personally i can't see that being used a lot until edge type devices are more common and not in the 2 years the contract will last for.
- How you you use screen protectors on the edge? A well known network told me to put a cheap protection them then very thin ones that bend, and not to use a good one...... not sure i believe that. All the screen protectors I looked at on Amazon for the Edge, shows a picture of either an S5 or an S6, but not the edge
- What type of case is good for the edge
- What use is the edge when its clamped into a car bracket ?
- Today i was reading about large amount of micro scratches on the edge, my guess these are polishing marks.
Andrew
