1. M Yousif's Avatar
    Hi Everyone, I am getting this error on my new s6 edge and cant seem to get the problem fixed. I cleared the cache and forcestop the application but still not able to fix the problem. The nightclock works fine, but when the phone is unlocked i cannot use people edge... Does anyone have a similar problem
    Thanks in advance
    04-11-2015 01:33 AM
  2. itguyjax8430's Avatar
    Thanks in advance
    Welcome to Android Central!
    Have you tried to clear the data from the app to reset it?
    04-14-2015 09:11 AM
  3. natedawg04's Avatar
    I'm getting the same error message, did you have any luck? I tried clearing the cache, no luck.
    04-23-2015 09:23 AM
  4. Allen_01000010's Avatar
    Thanks in advance
    I'm having the same issue as well. it started yesterday (5-26-2015). Don't have a solution yet.
    05-27-2015 10:07 AM
  5. Allen_01000010's Avatar
    Have you tried to do a hard reset?
    05-29-2015 09:25 AM
  6. TntNut's Avatar
    I FOUND THE SOLUTION , AFTER 2 WEEKS OF DEBUGGING . Ok I am so happy i found the problem , so the problem is that you erased or modified one of your edge contacts. In my case I had 5 contacts and I erased my 3rd contact so my phone didn't know what to do. I fixed it by going to settings, then to edge scree, then to my people , (also people edge has to be on even tough its not working so you can access the contacts) and then you should see that one of your contacts is not there. It will look like this:
    1. Contact 1
    2. Contact 2
    3. Add Contact
    4. Contact 3
    5. Contact 4
    And you just need to fill in the 3rd contact (it might be the 1st or the 2nd...)
    After you added your contact just restart People Edge and it should be working
    06-11-2015 07:01 PM
  7. Scott Williams9's Avatar
    My peoplestrips stopped working and I reset the data on it. It's not even letting me change my contacts it just keeps telling me unfortunately peoplestrips stopped working. Can anyone help me.
    07-09-2015 08:22 PM
  8. Jon-luke Belshaw's Avatar
    Uninstalling the updates worked for me.
    09-20-2015 08:04 AM
  1. Samsung Galaxy S6 font
    By beatsandlife in forum Samsung Galaxy S6
    Last Post: 07-11-2016, 11:36 AM
  2. Replies: 1
    Last Post: 04-11-2015, 03:50 AM
  3. Our 2 Galaxy 3 phones shut off & on.
    Last Post: 04-10-2015, 10:59 PM
  4. at&t galaxy s4 and s4 active ROM flashing...
    By Shervon Eleuthere1 in forum AT&T Samsung Galaxy S4
    Last Post: 04-10-2015, 10:56 PM
