The way to add an app to the home screen on Android is to open up the app drawer (bottom right icon), find the icon of your app and then hold down on it. That will then overlay the app icon over the home screen, and you can release your finger to place the icon there (drag and drop). Certain apps are located within the folders at the beginning of the app drawer (Google, Microsoft, Samsung), and for those, you just tap on the folder, find the app icons inside, and do the same drag and drop. It is also easier for me to find apps within my app drawer if I keep them alphabetized by tapping the "A-Z" button in the top right within the app drawer.
04-15-2015 08:44 AM
