1. AC Question's Avatar
    I am thinking of purchasing a Samsung S6 edge but my Bose sound system can only be connected to an iPhone 5... are there any products available that can make it possible to use my sound system with a Samsung ?? I have looked around but there are only Bluetooth adapters for iPhone 4's??
    04-15-2015 08:38 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which Bose system? Does it only connect to iPhones using the proprietary 30-pin connector? If so, then you won't be able to connect the S6 with that cable. You'd probably have to use a 3.5 mm male-to-male cable to connect the phone's headphone jack to the Aux input jack of the Bose system (if there's one available).
    04-16-2015 10:50 PM
  3. karmamule's Avatar
    Does it have DLNA? If so then you probably could get it to work that way.
    Also, check Spotify if you use it, as it's pretty good about picking up things like that. I hooked up a Denon HEOS the other day it popped up as an option in Spotify and I didn't have to do anything.
    04-17-2015 10:05 AM
  1. Replies: 5
    Last Post: 07-24-2015, 09:19 PM
  2. What is the best Keyboard app for my Note 4?
    Last Post: 06-15-2015, 05:59 PM
  3. I restarted my phone and now my music is gone!! How can I get it back?
    Last Post: 04-16-2015, 09:58 PM
  4. Can I unlock a Galaxy S4 SCH-R970C?
    By JonNewType in forum Samsung Galaxy S4
    Last Post: 04-16-2015, 11:23 AM
  5. Replies: 1
    Last Post: 04-15-2015, 11:24 PM
