1. AC Question's Avatar
    i'm a low tech gal I could access my calendar on on old HTC evo easily but don't know how on my new galaxy6x edge. your help appreciated
    04-16-2015 12:18 PM
  2. triscuit22's Avatar
    What calendar? Google? Ms exchange?
    04-16-2015 03:41 PM
  3. Richard Melton1's Avatar
    I logged on to my Google account and all of my contacts and calendar information downloaded (Synced) automatically.
    04-17-2015 11:35 AM
  4. Fedginator's Avatar
    On the calendar app and add whatever. There will be the opportunity to sync from previous e calenders (of you had one) is the app settings
    04-17-2015 03:37 PM
  5. Raptor007's Avatar
    When you set up your Google services, you should be able to go into the calendar app and select the Google related calendars you want, holidays, birthdays, etc.
    04-17-2015 09:02 PM
  6. Lil21kev's Avatar
    I used to use the Samsung calendar 📅 on my S3 but for some reason this calendar isn't syncing with Facebook etc
    04-18-2015 02:05 AM
  1. S6 Home Button Loose Rattle
    By jgscott987 in forum Samsung Galaxy S6
    Last Post: 11-20-2015, 12:03 PM
  2. How do I get 2 apps open at the same time, and each take up half the screen?
    By Harry_Yambag in forum Samsung Galaxy Note Edge
    Last Post: 04-21-2015, 12:32 PM
  3. Why does my phone keep turning on/off?
    Last Post: 04-16-2015, 05:56 PM
  4. how to set 3D weather report on display
    By Vel Pandi in forum HTC Desire 816
    Last Post: 04-16-2015, 05:55 PM
  5. Why is my Tab 2 gt-p3100 suddenly turning on again and again non stop?
    By AC Question in forum Samsung Galaxy Tab 2
    Last Post: 04-16-2015, 02:07 PM
