1. erasat's Avatar
    I think is good to mention that don't forget to go to the Galaxy Apps (Samsung Play Store) and download your Camera Add-On Modes.
    The better ones for me are the Rear-cam Selfie, Sports shot and Food shot. Rear-Cam selfies will use the great Rear Camera hardware and software to get your selfies and it will shoot automatically when it detects a face, great feature, the other 2 are self explanatory.
    Also, I posted this in another thread here but just in case you haven't see it, check the Pin Windows feature. For those of you that didn't know about it, or wondering what happened with this Lollipop feature on our phones, Samsung turned it off by default and it's basically buried under the Lockscreen Menu, if you want to look for it go to Lock Screen and Security- Other Security settings and you will find it there, or even easier, just go to settings and search for Pin Windows.
    Go and see what this little nice feature can do, but in a summary, any App or screen you want to have it fixed (Pinned) on your screen just press the Recent Apps buttons and it will allow you to pin it, you won't get out of that screen until long press the Recent Apps again.
    I can tell you that for me is very useful because I use a couple of Online Games that are played directly on the browser and you don't have a clue of how many times I've lost or simply needed to begin again because I hit the back or recent apps capacitive buttons. That's just one of the reason but I can think of a couple more.
    Sammuel1973 likes this.
    04-22-2015 01:20 PM
  2. Raf's Avatar
    I can't find any of those camera add ons you spoke of. And yes, I am in Galaxy Apps.
    04-22-2015 04:43 PM
  3. erasat's Avatar
    Well, it's weird because I downloaded all of them from the Galaxy apps, I noticed though that in order to search you basically need to match the whole name as it didn't find one or 2 because I didn't use the correct name.
    The exact names as they appear are Rear-cam Selfie, Sports shot and Food shot. (I edited the OP to show the correct names)
    04-22-2015 04:52 PM
  4. f308gt4's Avatar
    I downloaded them directly from the Camera. Go to camera, and under modes, there is an option to download. Press that button, and it takes you to the store to download the modes.
    04-22-2015 05:06 PM
  5. Denisew 1972's Avatar
    I also downloaded directly from the camera. Super easy and they are very useful.
    erasat likes this.
    04-22-2015 05:23 PM
  6. erasat's Avatar
    Yes, that also works since galaxy S4 I think, I forgot about it, I simply downloaded them directly from the store because I was already there downloading other apps.
    04-22-2015 05:44 PM
  7. Raf's Avatar
    Ah okay...this might be the ticket for me then.
    04-23-2015 11:35 AM
  8. briggy79's Avatar
    Just downloaded, thank you.
    04-23-2015 05:29 PM
  1. How to forward number from phone log
    By Reliablehome in forum Samsung Galaxy S6 edge
    Last Post: 10-28-2015, 08:43 AM
  2. Where is the document file located on the Galaxy 5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-23-2015, 11:15 AM
  3. Best way to use my UK phone in America?
    By nickname303 in forum Moto X
    Last Post: 04-23-2015, 06:07 AM
  4. How do I make Google Voice calls from my ATT Galaxy S4 mini?
    By AC Question in forum Samsung Galaxy S4 Mini
    Last Post: 04-22-2015, 05:22 PM
  5. Samsung Galaxy S5 Stuck in Download Mode
    Last Post: 04-22-2015, 01:07 PM
