Originally Posted by
AC Question Upgraded from an S4 eight days ago, having serious connectivity issues with the S6 Edge. Find myself having to re-send texts 2 or 3 times; receive network connectivity error, calls won't come through and I just end up receiving a voicemail. I didn't have these issues with the S4. Went to the Sprint store and a Rep told me it's a S6 Edge issue and I should return it and get an S6 instead.
Hi there
I recently bought the S6 Edge and after 7 days returned it and swapped it for another one because my calls kept getting disconnected, calls coming in get disconnected it normally takes 5 attempts to get through to me, I have had my replace phone for 5 days and it's doing the same thing, fustrating as the store say they have never had this issue before yet this is the 2nd phone for me and it's doing it. I now have to send my phone away for repair. Do you get anywhere with your problem? Appreciate a reply. Also, I tried my sim card in my iPhone also and it worked fine plus I have had this sim card for 2 years at least. Thanks
