For some reason, the native alarm feature ONLY allows you to snooze for 5 minutes 3 times. No more choosing your own snooze options.
What is this? Apple?
Printable View
True....this really bugged me.
Yeah, I just downloaded another one
Yeah i also was annoyed by this. True you can download another alarm app, but didn't want to start cluttering up the phone with apps that shouldn't be necessary.
Learn to wake up better..... Totally kidding this is going to **** me off too when I get the edge. I'm a 15min x 4 times snooze guy lol.
It's annoying. I'm a 10 min snooze man x2 and it's silly not having the option to change it. Hopefully they can update this.
Ha!
My complaint about the stock alarm clock is if you change the alarm tune and set it to ramp up the volume and then set a second alarm you have to change those options again for the second alarm. Any way to change the default on those options?
If I change to an alarm clock app can Google Now set the alarm for you or will that set the stock alarm clock?
I know you can set Timely through Google Now as they've added this functionality in. I think it depends on the app you have and whether the developer has made it compatible.
How? I looked at the settings bit I don't see anything to set it to trigger with google now.
Update: nvm figure it out :)
