1. AC Question's Avatar
    Hi I recently upgraded from an S4 to S6 edge.
    all is going well except for in the last hour my home button isn't working properly.
    the only thing it does it wake the screen up from sleep, double tapping to open camera does nothing, pressing it when in an app to go back to home screen also does nothing
    04-25-2015 03:22 AM
  2. belodion's Avatar
    Welcome to Android Central.
    You could register here and try posting in the S6 Edge forum about that, but I'm not sure that there's anything you could do to fix it yourself. Be prepared to return it.
    04-25-2015 05:44 AM
  3. NewtoAndroid15's Avatar
    Restarting my s6 edge fixed it for me...try that maybe?
    05-26-2015 05:24 PM
  4. macdarwin's Avatar
    Or factory reset as well
    05-26-2015 05:25 PM
  5. goldust74's Avatar
    my galaxy s6 edge is doing the same thing. it started doing this in the last few days. ive had it over a year and never had a problem with it. ive reset, rebooted, u name it. wtf!
    07-26-2016 11:28 PM
  6. Micanic84's Avatar
    Did you figure out a fix yet? Mine just **** out, I've tried numerous restarts, it won't go into safe mode, and I'm sure not doing a factory data reset. Too much stuff to lose.
    08-21-2016 07:17 PM
  7. Tech-Newb's Avatar
    Well if it wont go to safe mode, maybe the home button is dead already. Make a backup with samsung smart switch on PC. It will backup all your pictures, notes, music, etc. then factory reset it. If it doenst fix the home button, send your phone to repair.
    Posted with ❤Love❤
    08-22-2016 04:24 AM
  8. Thebesttoo's Avatar
    09-21-2016 06:51 AM
  1. 'Application not found' for all apps on SD, why is that?
    By Guy Corbett in forum General Help and How To
    Last Post: 06-30-2017, 10:02 PM
  2. Gear VR for S6/S6 Edge pre order started today
    By mxrider821 in forum Samsung Galaxy S6
    Last Post: 05-10-2015, 08:16 AM
  3. YouTube 360 Degree Videos on Galaxy S6 = AWESOME
    By smooth4lyfe in forum Samsung Galaxy S6
    Last Post: 04-27-2015, 08:51 PM
  4. Replies: 1
    Last Post: 04-25-2015, 07:03 AM
