Originally Posted by
murrelldj28 Hi All... Anyone aware of any alternative lock screens that can be applied but still use the fingerprint scanner to unlock??
I suspect there are none... have searched but found nothing. I have nothing against the set lock screen, but would like to be able to apply widgets such as calendar.
Thanks
C Locker worked great last year with S5 and fingerprint, I used for months until I got the Lollipop in my phones, I really like Lollipop Lockscreen so I haven't used C Locker for a while, but you can try to see if the Author already updated the app to use the S6 fingerprint also, I think it should work but give it a try.
Look at this thread I created last year for the S5.
http://forums.androidcentral.com/sam...gets-more.html
