1. dynot's Avatar
    Occasionally my double-clicking of the home button does not launch my camera. To get that working again I have to go into setting turn off that feature and turn it back on. Anyone else experience this?
    04-25-2015 07:45 PM
  2. CLC81's Avatar
    I'm experiencing the same problem. Are you using NovaLauncher?
    04-25-2015 08:31 PM
  3. SCORPZ040's Avatar
    I Am having the exact same issue too !!...I am now going to try a factory reset .....
    05-20-2015 07:24 AM
  4. dynot's Avatar
    No, I'm using stock.
    The only way to get it back is clicking on the camera icon. After that double-clicking works. FWIW I'm on Rogers and I also find it is a little slow snapping photos. Definitely not as fast as early reviews made it out to be.
    05-20-2015 07:35 AM
  5. duggers2368's Avatar
    I have the same problem. I find that it corrects itself if you open the camera And then take a picture with the lower volume button. Close the camera app and lock screen it should work now when you double tap the volume button. This is obviously a software glitch.
    I hope this works for you all.
    07-05-2015 12:47 PM
  6. Momorox's Avatar
    Mine stopped working and I have no idea how to get help on that.. which settings field does that come under?
    08-06-2015 04:40 AM
  7. twoblu1s's Avatar
    I'm using the Samsung Galaxy S6. I was having the same problem with double clicking the home key to bring up my camera (I think the last update they did affected this). What you need to do is open your camera with your camera app, go into settings in the upper right hand corner and flip back on "quick launch" ...it worked for me :-)
    01-21-2018 03:32 PM
  1. Camera recommendation
    By Fred Wilson2 in forum LG G3
    Last Post: 04-27-2015, 12:39 AM
  2. Getting pictures off phone memory with broken screen?
    Last Post: 04-25-2015, 07:21 PM
  3. Can I hook a phone up to a tv with rca cables to watch video from phone?
    Last Post: 04-25-2015, 07:11 PM
  4. What is wrong with my Samsung Galaxy S3 Mini?
    Last Post: 04-25-2015, 07:10 PM
  5. Replies: 0
    Last Post: 04-25-2015, 07:09 PM
