1. jcarrero's Avatar
    Guys,
    I have used Helium beefore with many other devices. I can't get it to work on the Edge. I have the correct adb drivers but it wont allow the backups. In the other computer Helium says the device is unlocked by my Edge never leaves the waiting for application screen. Any ideas?
    04-28-2015 07:41 PM
  2. erasat's Avatar
    Guys,
    I don't know what may be wrong with yours as it's working great for me, only thing in there are correct drivers, so when you connects if to your PC, does it get recognized correctly?, also, in other devices there was an issue where it only worked when changing the USB connection type to mtp or whatever is called, when you connect it to the PC just see if you have that option on the phone notifications.
    For last, and I'm just asking just in case, but do you have USB debugging enabled and have validated the credentials with the PC already? Just in case you have done it, try going to the developer options and click on Revoke USB debugging authorizations so it can ask you for it again next time you connect it to the PC.
    04-28-2015 08:18 PM
  1. How can I send pictures from my S6 via text messages?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-21-2016, 09:26 AM
  2. S3 mini charging question/problem
    By Lucy Davies in forum Samsung Galaxy S3 Mini
    Last Post: 05-01-2015, 08:08 PM
  3. Just Picked up my Gold 64GB Edge...Questions
    By AspenQn in forum Samsung Galaxy S6 edge
    Last Post: 04-29-2015, 01:18 PM
  4. New Verizon Note Edge and questions, can I get some help?
    By AC Question in forum Samsung Galaxy Note Edge
    Last Post: 04-28-2015, 07:29 PM
  5. PocketNow quick review - S6 vs LG G4
    By Techno-guy in forum Samsung Galaxy S6
    Last Post: 04-28-2015, 07:26 PM
