Dancing between iPhone and S6E for the last two weeks...help!
anon(5373819)
193
I'll chime in. Battery 'was' terrible for me too. I had to turn off VoLTE. Improved dramatically.
However I'm literally on my third S6 Edge, the first on March 23.
GPS issues, software issues, and now potential fingerprint issues.
shath32
8
Sorry to hear that :/ I'm really worried about the signal when I get this second edge
anon(1733)
2,547
I won't know my battery life for a few charge cycles. But then first thing I always do on a android phone is disable all the bloat I'm the phone. Especially the verizon crap. The verizon caller ID is a huge battery killer.
shath32
8
I probably should've done the same. I probably will when I get it tomorrow. I'm just hoping I don't have signal problems..
anon(1733)
2,547
You know what I found. I switched my carrier network settings to LTE/CDMA and my signal went from two bars to full. Under setting and mobile network at least on verizon mine defaulted to global. I changed this to the above and now it's Perfect.
shaneontherocks
357
//images.tapatalk-cdn.com/15/05/01/ff654ef1e9dce12cdc9b441220c79eac.jpg
should I change mine to LTE/CDMA only? I am on Sprint s6edge... would it make a difference in battery? I have mine set on automatic (phone came with this setting applied). which is better to use?
Finsrepair
