1. DSMpowerhousegroup's Avatar
    Looking for a leather holster that comfortably holds and protects my device while carrying. One I'm using now is too tight. Would Walmart carry something like this? Local Best Buy had nothing that was really large enough.
    05-01-2015 02:43 PM
  2. lousvette's Avatar
    Verizon has some
    05-01-2015 02:47 PM
  3. DSMpowerhousegroup's Avatar
    Verizon has some
    Everything my local store had was too small.
    05-01-2015 02:52 PM
  4. koreaa30's Avatar
    I noticed ebay has a few options.
    05-01-2015 08:32 PM
  5. DSMpowerhousegroup's Avatar
    Yes. Was trying to find something I could just walk into the store and buy. I might have to go that route.
    05-01-2015 09:32 PM
  6. swingarm's Avatar
    Radioshack?
    05-01-2015 10:57 PM
  7. DSMpowerhousegroup's Avatar
    Radioshack?
    I'll check. Probably just have to order online. Thanks.
    05-01-2015 11:06 PM
  8. yocubed's Avatar
    I am using the best buy platinum case for the S6 edge. I use it with my Ringke Fusion case. It's a touch loose in the holster but won't fall out. I put mine through pretty good abuse at work and haven't had an issue.
    This one which apparently is no longer available
    http://www.bestbuy.com/site/platinum-case-for-samsung-galaxy-s-6-edge-cell-phones-black/3938926.p?id=1219611682726&skuId=3938926
    Sorry didn't realize you were looking for a leather holster, disregard the above.
    05-02-2015 01:23 AM
  9. DWS44's Avatar
    I've been a fan of Monaco leather belt clips/holsters. I had two on hand when I got the S6 and actually found both of these to work depending on whether you keep your phone in a case, or go without one.
    First is the one I originally purchased for the old HTC Evo LTE, and also used with my M7. If you are NOT using a case the phone fits pretty well. It holds the phone tight enough to not fall out, but you can easily pull it out. Its not quite tall enough to cover the entire phone, but it sticks out less an 1/4". Close enough for me:
    http://www.amazon.com/gp/product/B00...cUvbUpU4401791
    I also have the following one that I bought while I briefly had an HTC M8. On occasion I use a Spigen Ultra-hybrid case for the Edge when I'm going to be in rough environment, and found the phone inside the case fits perfectly in the larger holster intended for the M8!
    HTC One M8 Monaco Vertical Pouch Type Leather Case - Black
    05-02-2015 09:40 AM
  1. Hour notice for gear S?
    By Petr Monty in forum Samsung Gear S
    Last Post: 06-30-2015, 12:26 PM
  2. What new phone should I get?
    Last Post: 05-02-2015, 07:34 AM
  3. Replies: 1
    Last Post: 05-01-2015, 10:51 PM
  4. Theme Store galaxy s6
    By Deepburn in forum Samsung Galaxy S6
    Last Post: 05-01-2015, 12:57 PM
