Galaxy S6 Edge Camera Failed Error
Problem: Hi guys! I recently encountered a problem with my new Galaxy S6 Edge and I think you’d be the first one I’d tell you about it. I am not so sure what happened or what I’ve installed but the phone will now pop up the error message “camera failed” every time I open the camera. Prior to this, I was able to take a lot of pictures and it just frustrates me to be greeted with this error message every time I want to use the camera. I am not new to technology but this is my first Android phone (I’m a long time iPhone user) so please don’t be too hard on me. Thanks. — Sarah
Troubleshooting: Hi Sarah! I am sorry to hear your first Android experience is not so smooth. I really can’t tell what’s wrong with the camera of your phone based on your description but if it’s not the firmware, then it’s gotta be the hardware that has a problem. But first of all, I will assume that the phone doesn’t have physical or liquid damage.
The first thing you need to do is determine whether it’s a third-party app (which you may have installed) that’s causing the problem or anything else. To do that, boot the phone in safe mode:
Turn off your Galaxy S6 Edge.
Press and hold the Power key.
When ‘Samsung Galaxy S6 Edge’ appears, immediately release the Power key and then press and hold the Volume Down button.
Continue holding the Volume Down button until the phone finishes the restart.
When you see Safe Mode on the lower left corner of the screen, release the button.
If it were just a third-party that caused it, then the camera should work in safe mode. If not, then it must either be the firmware or the hardware itself.
A hard reset is necessary to determine if bringing the phone back to its factory settings will fix the problem. If not, you need to talk with your provider and have the tech take a look at it or request a replacement unit.
Full Hard Reset
Turn off your Samsung Galaxy S6 Edge.
Press and hold the Volume Up, Home and Power keys together.
When the device powers on and displays ‘Power on logo’, release all keys and the Android icon will appear on the screen.
Wait until the Android Recovery Screen appears after about 30 seconds.
Using the Volume Down key, highlight the option, ‘wipe data/factory reset’ and press the Power key to select it.
Press the Vol Down button again until the option ‘Yes — delete all user data’ is highlighted and then press the Power key to select it.
After the reset is complete, highlight ‘Reboot system now’ and hit the Power key to restart the phone.
