1. AC Question's Avatar
    Hi,
    I've recently moved from a HTC One XL to the Galaxy S6 Edge.
    This is a minor inconvenience, but I'm trying to find a simple calculator widget. I use it a fair bit and like the convenience of just swiping to my calculator.
    Any help, recommendations would be greatly appreciated!
    I downloaded the CALCU stylish calculator, but I've no idea how widgets work, does it automatically offer me the option of using the widget from downloading the app?
    - Feeling like a huge simpleton
    05-05-2015 08:09 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! To add a widget, long-press any blank area of the homescreen, then select Add Widget. You can see all available widgets in the subsequent list.
    The Calcu app description doesn't mention a widget, so you might not see one. Try Calculator (CyanogenMod).
    05-05-2015 11:47 PM
  3. ilordvader's Avatar
    05-12-2015 11:01 PM
  1. Iron man S6 and S6 edge is coming
    By Jermaine Gray in forum Samsung Galaxy S6
    Last Post: 06-18-2015, 08:53 PM
  2. Tempered Glass Protection For Edge
    By DSMpowerhousegroup in forum Samsung Galaxy S6 edge
    Last Post: 05-06-2015, 03:41 PM
  3. Is there a way to animate the charging notification LED?
    By Christopher Swierczynski in forum Samsung Galaxy S5
    Last Post: 05-06-2015, 11:48 AM
  4. Replies: 1
    Last Post: 05-05-2015, 08:27 PM
  5. Replies: 1
    Last Post: 05-05-2015, 08:26 PM
