1. the egg's Avatar
    I download the update but when I attempt to install it I get a message saying "update" failed. Any way to fix this?
    05-14-2015 09:21 AM
  2. Cowboy8467's Avatar
    Are you rooted?
    05-14-2015 09:27 AM
  3. the egg's Avatar
    I just got this phone lol
    05-14-2015 09:28 AM
  4. erasat's Avatar
    If by you just got it, you mean that you just got it and immediately you had the update notification, not too much settings and stuff you may lose, I'd definitely do a Wipe Cache partition and Wipe data/Factory reset, both in Recovery Mode and then set your stuff again and see if you can install the update. Then after the update, I'll always advice to go back to Recovery Mode and do just the Wipe cache Partition.
    05-14-2015 09:50 AM
  1. Replies: 3
    Last Post: 06-15-2016, 09:21 PM
  2. Why won't my Samsung Galaxy Tab 3 turn on?
    By AC Question in forum Samsung Galaxy Tab 3
    Last Post: 05-31-2015, 11:56 AM
  3. Replies: 8
    Last Post: 05-15-2015, 08:27 AM
  4. Why don't Bluetooth controls work after latest update?
    By Zachary Fowler1 in forum Samsung Galaxy S5
    Last Post: 05-14-2015, 08:56 AM
  5. Nexus 7 St gen won't charge up or turn on.
    By scott0121 in forum Google Nexus 7 Tablet (2012)
    Last Post: 05-14-2015, 08:55 AM
