1. Lone Wanderer 216's Avatar
    Last night before I went to bed I plugged my phone in at around 8% and when I woke up a in the morning I was using it and noticed it was at 73% i figured maybe it got unplugged. But it was still charging. And stayed at 73% forever. Restart seemed to fix it. Any idea why this would happen? Anyone else have this issue?
    05-15-2015 08:29 AM
  2. srkmagnus's Avatar
    There could have been a wake lock and an app was running preventing the device from sleeping and/or charging. It's good to see that a reboot fixed it; if you see this happen again, consider checking the battery usage stats and see if there's an app running that shouldn't be.
    How are you liking the S6 Edge?
    05-15-2015 10:00 AM
  3. Lone Wanderer 216's Avatar
    Okay thank you. And ive had it since release day, I was one of the people that had a unit that had scratches if you looked at the phone in sunlight ( from the polishing process I have been told ) but other then that, phone is awesome. No complaints at all really.
    05-16-2015 09:15 AM
  4. DoggyB22's Avatar
    Does the Edge use the same charger as the S5?
    05-17-2015 12:10 AM
  5. dpham00's Avatar
    No
    Sent from my Pearly White Verizon Samsung Galaxy S6 Edge
    05-17-2015 07:48 AM
  1. Why does my Galaxy S6 have a vibrator rattle noise?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-15-2015, 10:47 AM
  2. How to fix microphone issues for LGG2?
    Last Post: 05-15-2015, 09:54 AM
  3. WiFi issues
    By Droid669 in forum Moto X
    Last Post: 05-15-2015, 08:01 AM
  4. Where can I find some more Edge screen apps to download?
    By stonefox in forum Samsung Galaxy S6 edge
    Last Post: 05-15-2015, 06:48 AM
  5. does s6 messaging app
    By JohnCenaFan in forum Android Wear / Wear OS
    Last Post: 05-15-2015, 03:54 AM
