05-28-2015 11:54 PM
26 12
tools
  1. shadow82x's Avatar
    So last night I noticed that there appears to be a thin line of light coming up from above both the right and left bezel. Can anyone else reproduce this? It's most noticeable in a dark environment with the screen brightness relatively high.
    See my pics for reference in second post.
    05-16-2015 12:25 PM
  2. shadow82x's Avatar
    Attached are actual photos from a dark room. Is this unique to my device or do others have leakage above the bezel?
    Attached Thumbnails Light Leakage Around Bezel?-imag0018.jpg   Light Leakage Around Bezel?-imag0020.jpg   Light Leakage Around Bezel?-imag0021.jpg
    05-16-2015 04:51 PM
  3. spawn9859's Avatar
    Mine has the same problem
    05-16-2015 09:58 PM
  4. shadow82x's Avatar
    I'm wondering if its like this for all devices. Which is why I'm not sure if I should exchange or not. It's not one of those things that can easily be tested in a store because it's hard to tell in lighted situations.
    05-16-2015 10:14 PM
  5. spawn9859's Avatar
    I can let you know Tuesday, I work at at&t and have someone coming in to buy one. We currently don't have a floor model for some reason. I'll just turn the lights off and see.
    05-17-2015 12:23 AM
  6. shadow82x's Avatar
    Awesome! Be sure to let me know. Also would be helpful if some other community members can chime in here. It's rather annoying now that I noticed it..if I hadn't I wouldn't consider exchanging this heh.
    05-17-2015 12:35 AM
  7. orangemartini's Avatar
    No mine does NOT do that, nor did the one I had for nearly two weeks that I returned for overheating issues. Take it back!
    05-17-2015 03:19 PM
  8. shadow82x's Avatar
    Thanks for the reply. Now I know it's defective. Anyone know if I can stop in a best buy to get this handled ?
    05-17-2015 04:55 PM
  9. RN50's Avatar
    Does your phone overheat or have a rubbish battery life? If not do u really want to trade it in for a new phone that might have these issues for something so small as a tiny little light coming from the sides?
    05-17-2015 05:46 PM
  10. shadow82x's Avatar
    My battery life has been pretty subpar with it usually under 4 hours SOT. I have had screen defects in the past which makes me iffy though.
    05-17-2015 06:20 PM
  11. kioko91's Avatar
    Mine and my mother's both have a glow on both edges when the screen is bright.
    05-17-2015 06:26 PM
  12. shadow82x's Avatar
    Thanks for your reply. Still trying to decide if it's worth an exchange.
    05-17-2015 09:31 PM
  13. NoahsArk97's Avatar
    Mine doesn't do that....
    05-17-2015 10:31 PM
  14. shadow82x's Avatar
    Guessing it's a defect with a small number of them. I also noticed there is light leak by the capacity buttons. I don't remember my other Edge's having any of these. Thinking the screen just isn't sitted properly.
    05-17-2015 11:36 PM
  15. LeoRex's Avatar
    To my untrained eyes, that looks like the display isn't properly fitted to the frame, hence the light bleed.
    05-18-2015 10:17 AM
  16. shadow82x's Avatar
    Spoke with Verizon and they didn't think it was normal so they're sending me a like new replacement. Anyone have any experience with their replacrments? Hopefully it's as good as a new phone
    05-18-2015 03:52 PM
  17. orangemartini's Avatar
    I hate to be negative here, but I had three replacements sent to me before I got one that didn't have something wrong with it (one was covered with scratches, one was the wrong phone entirely, one had a display that was pink on the bottom third of the phone). The one I ended up keeping, I bought right from the store, and I returned the original one to t-mo.
    But I think you should persevere until you get a phone that doesn't have any problems!
    05-18-2015 05:57 PM
  18. shadow82x's Avatar
    Was that replacement from t-mo or verizon? I'm a pretty big tech geek so I'll be on this phone all the time, and won't settle for anything less. (It's also why I have insurance) I'm interested to see if this replacement will have the light leak issue fixed and better battery than my current phone.
    05-18-2015 06:49 PM
  19. orangemartini's Avatar
    All t mobile phones I'm talking about here
    05-18-2015 10:30 PM
  20. shadow82x's Avatar
    Any updates? My replacement hasn't come in quite yet.
    05-21-2015 06:45 PM
  21. shadow82x's Avatar
    Got my replacement. Has the same exact issue. Guess I'll just settle with it and accept its normal. Sigh.
    05-22-2015 04:35 PM
  22. shadow82x's Avatar
    So now that auto rotate broke on the replacement. Ugh. My luck with phones... Time for another replacement :/
    05-27-2015 12:52 PM
  23. sup3r1or's Avatar
    Trust me this is nothing compared to what I had to go through with my HTC One M7 3 repairs in total 6 months in the repair.
    05-28-2015 02:22 AM
  24. RN50's Avatar
    Hopefully its third time lucky for you. i've got abit of light around the sides like you but it doesnt bother me too much as everything else works flawlessly. Can easily get 4-5+ Hours of SOT time (Best being almost 6 Hours). Phone doesnt really overheat for me, max temperature its been on is 32C which is around 89F.
    05-28-2015 04:04 AM
  25. shadow82x's Avatar
    The 2 replacements I've had both had a little bit of light leakage around the bezel so I'm not too worried about it anymore. I've accepted it's normal haha.
    05-28-2015 01:13 PM
26 12
  1. How do I reinstall assertive light on S4 Active?
    By Bob Call in forum Legacy Android & Other OS's
    Last Post: 05-13-2015, 12:54 PM
  2. Why message and missed call light won't stop blinking?
    Last Post: 05-13-2015, 11:45 AM
  3. Battery dies - blue LED light
    By Brandwin in forum Samsung Galaxy Note 4
    Last Post: 05-13-2015, 10:02 AM
  4. Replies: 1
    Last Post: 05-12-2015, 03:39 PM
