View Poll Results: How much your battery drained during sleep
Voters
2. You may not vote on this poll
  • 50%+
    0 0%
  • 40%+
    0 0%
  • 30%+
    0 0%
  • 20%+
    0 0%
  • 10%+
    1 50.00%
  • 0%+
    1 50.00%
  1. Emerson Xu's Avatar
    Normally the battery drops about 20% per night. Occasionally it's kind of hot/warm and more than 50% dropped. I used an iphone 5 before S6 EDGE, and it dropped around 10~15% per night.
    Where I sleep has a good 4G signal and WIFI signal. I haven't turned on the "don't disturb" option when I sleep. Also, due to the unacceptable quick power consumption, I have turned on power saving mode all the time, although this makes switching apps slower.
    05-16-2015 10:20 PM
  2. erasat's Avatar
    5% in an 8 hours sleep night, 4% when about 6-7 hours.
    Have you followed the tweaks and suggestions posted on the regular s6 forum and in other threads? I'd suggest you to look for it and follow those plus doing the Wipe cache Partition. Read well and disable bloat and unnecessary syncing apps plus turn off smart network and Scanning always allowed in wifi settings.
    05-16-2015 10:36 PM
  3. bembol's Avatar
    I'm using Battery Widget Reborn and put it in Night Mode, woke up after 7 hours with 96%.
    SHIFT_sixty four s6 edge
    05-17-2015 07:04 AM
  1. Which Project Fi Coverage Map Is Correct?
    By clairez1 in forum Google Nexus 6
    Last Post: 05-17-2015, 01:49 PM
  2. Is Anyone Getting This Much SOT
    By DSMpowerhousegroup in forum Samsung Galaxy S6 edge
    Last Post: 05-17-2015, 12:55 PM
  3. How do I take swype off of my phone that is a Kyocera phone?
    Last Post: 05-17-2015, 01:57 AM
  4. Replies: 1
    Last Post: 05-16-2015, 11:46 PM
  5. Is there life in Android Central ?
    By alfonso molina in forum Ask a Question
    Last Post: 05-16-2015, 09:55 PM
