1. jpullins's Avatar
    My phone died overnight...So I charged it to full this morning once I got up. Everything works as it should except for the touch key lights that flank the home button. They won't come on and there's no feedback either. Anyone else encounter this problem? Is there a fix I can do? Any help would be appreciated.
    05-23-2015 08:29 PM
  2. purpleclad's Avatar
    Do you have power save turned on?
    05-23-2015 08:33 PM
  3. jpullins's Avatar
    Power saver is not on
    05-23-2015 09:00 PM
  4. jcp007's Avatar
    Settings/Display/Touch Key Light Duration. It may be set to always off. See if this helps.
    05-23-2015 09:06 PM
  5. jpullins's Avatar
    Done that too.. Turned them to always on then reset my phone and still doesn't work
    05-23-2015 09:12 PM
  6. jcp007's Avatar
    Try clearing the app storage cached data in Settings.
    Then, clear the cache partition.
    Turn the device off.
    Hold volume up+home+power at the same time.
    Use the volume rocker to toggle to clear cache partition. Power button to select.
    When complete, use volume rocker and select reboot. Power to select.
    Once it comes back let us know.
    05-23-2015 09:41 PM
  7. jpullins's Avatar
    Cleared the cache...Still nothing. That was the first thing I did this morning and just tried again... Nothing changed
    05-23-2015 10:05 PM
  8. jcp007's Avatar
    Factory reset in Settings
    05-23-2015 10:17 PM
  9. jpullins's Avatar
    That's what I'm probably going to have to do. But I'm not going to do it now. Maybe after some other time. Thanks for all the help guys
    05-23-2015 10:19 PM
  10. jcp007's Avatar
    If the reset doesn't help, then call tech support to document your issues and start the exchange process.
    05-23-2015 10:43 PM
  11. jpullins's Avatar
    Will do thanks
    05-23-2015 10:47 PM
  12. jrb7561's Avatar
    To fix this, go to power saving mode and change it so that it's on immediately. After its on, turn it back off. Hopefully that should work. Sometimes when the battery dies completely on this phone it borks the power saving mode so that the capacitive buttons have no feedback.
    jcp007 likes this.
    05-23-2015 11:59 PM
  13. jpullins's Avatar
    Wow that worked....can't believe something so simple worked lol. Thank you!
    05-24-2015 01:23 AM
  14. jcp007's Avatar
    That's a great tip. Since I never let my battery run so low, I had never experienced things getting borked.
    05-24-2015 07:24 AM
  15. Arik Brown's Avatar
    Wow, this worked for me as well. Thank you!
    04-11-2016 07:37 PM
  1. Alcatel One Touch Idol X keeps vibrating, won't turn on. What should I do?
    Last Post: 04-06-2017, 09:54 AM
  2. galaxy note 4 soft keys faint flicker
    By Joshua Motley1 in forum Samsung Galaxy Note 4
    Last Post: 05-24-2015, 12:20 PM
  3. Light Flow help?
    By leafcat in forum Samsung Galaxy S5
    Last Post: 05-24-2015, 09:33 AM
  4. Does the front keys on a galaxy tab 4 10.1 light up ?
    Last Post: 05-23-2015, 05:29 PM
  5. Where can I buy a Galaxy Light wireless charger?
    By tecgayz in forum General Help and How To
    Last Post: 05-23-2015, 04:45 PM
