1. PFonte4's Avatar
    Simple question. Does anyone know if the edge function on the note 4 edge will ever be applied in an update to the 6?
    Absolutely love my 6 edge but how can Samsung come out with a Note 4 edge that allows you to add apps to the edge and yet they introduce a flagship phone in the 6 edge and it can't?
    05-26-2015 02:37 PM
  2. The Cynical Canuck's Avatar
    No the edge is too small.
    Posted via the Galaxy S6 edge
    05-27-2015 06:00 PM
  3. sup3r1or's Avatar
    I really wish they would do something with an edge on S6, but it seems like it is a design over function at this point.
    05-28-2015 02:12 AM
  4. C5p0's Avatar
    It's been done.. just add apps bar from the Playstore and you are all set
    05-28-2015 08:21 PM
  1. My Samsung Galaxy tablet screen has frozen, how can I fix it?
    By AC Question in forum Samsung Galaxy Tab
    Last Post: 12-20-2015, 02:55 PM
  2. Why does the s6 edge go to the play store?
    By irocroe in forum Samsung Galaxy S6 edge
    Last Post: 05-28-2015, 02:06 PM
  3. Why i cant use any headphones on my galaxy s5?
    By beyondstrike in forum Ask a Question
    Last Post: 05-26-2015, 04:16 PM
  4. Wifes S6 can quick reply but my Note4 cant, why?
    Last Post: 05-26-2015, 04:04 PM
  5. Replies: 0
    Last Post: 05-26-2015, 01:42 PM
