1. AC Question's Avatar
    connect to open wifi is no issue.
    try add network enter network SSID and security WPA/WPA2/FT PSK. and enter password but noting appear
    06-01-2015 06:18 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you tried unhiding the SSID in the router settings, then making the initial wi-fi connection on the phone, then going back to the router and hiding the SSID again?
    06-01-2015 12:58 PM
  3. Crashdamage's Avatar
    Try this:
    Set security encryption to WPA2/AES. Do not use WEP, WPA2/TKIP or WPA2/AES/TKIP.
    Unhide the network and try to connect. If it works, you can hide the network and try again.
    Personally, if making the network SSID visible makes it work, I'd leave it that way. Hiding the SSID really does nothing for security. It's the password that matters.
    Android user since v1.0. Linux user since 2001.
    B. Diddy likes this.
    06-01-2015 01:42 PM
  1. Why does my Note Edge vibrate without any notification or text/call?
    By Kheang Sok in forum Samsung Galaxy Note Edge
    Last Post: 07-06-2015, 08:43 AM
  2. Galxy S6 Edge: Very disappointing :(
    By mevolcom3 in forum Samsung Galaxy S6 edge
    Last Post: 07-01-2015, 09:03 PM
  3. Replies: 2
    Last Post: 06-17-2015, 12:57 PM
  4. Did the Google Nexus 5 5 5.1.1 update improve your battery life?
    By fabian bonifacio in forum Google Nexus 5
    Last Post: 06-04-2015, 08:34 PM
