1. recDNA's Avatar
    Since lollypop update my Note 3 underlines spelling errors in red. I hate auto correction but love the red underlining feature. You need to install google keyboard for it to work however you don't need to use google keyboard. Just have it installed. This feature never worked on note 3 until 5.0 update. I'm at an ATT store at the mall and I installed google keyboard in the s6edge but I cannot seem to get the red underlining to work? Would someone else try and let me know? A screenshot would be great confirmation. I really need this feature. It draws my attention to possibly misspellings without changing them. I use a lot of jargon that gets "autocorrected" into jibberish if I use normal autocorrection. Thanks
    06-05-2015 11:49 AM
  2. sjaduae's Avatar
    I think you need to set auto replace off but auto spell check on from settings/language and input/Samsung keyboard
    It states quite clearly in the description that red underline appears with auto check spelling
    06-06-2015 04:20 AM
  3. recDNA's Avatar
    That never worked before lollypop. Can you get the red underlining without google keyboard installed?
    These are my options in Sammy keyboard. The one you mentioned is not there. Ironically, due to Google keyboard, the red underlining works everywhere except samsung stock email and samsung stock messages. For example it does work in outlook or gmail.
    06-07-2015 01:11 PM
  4. btgrave's Avatar
    You don't need to install Google Keyboard for it to work.
    I only have the stock Samsung Keyboard, and the red lines show up during my spelling errors.
    06-08-2015 09:44 AM
  5. recDNA's Avatar
    Do they work in stock messages and stock samsung email?
    06-08-2015 03:13 PM
  6. recDNA's Avatar
    I cannot find the setting you speak of. Please see picture 2 posts up.
    06-08-2015 03:15 PM
  7. sjaduae's Avatar
    I noticed your screen is very different to my one I have 2 options above your screenshot for input languages and then after your auto replace I have auto check spelling and text shortcuts after your screenshot there is another 3 options for key tap feedback and two other settings for adjust KB size and reset settings
    Also my toggles are a switch not a tick box
    Have you set your language and default KB to Samsung ? are you running 5.02 ?
    06-09-2015 02:21 PM
  8. recDNA's Avatar
    I'm VZW so running 5.0.1
    06-09-2015 04:04 PM
  9. Mike1117's Avatar
    I'm on VZW too and cannot get the red underlines to show up for spelling errors.
    06-10-2015 10:50 AM
  10. recDNA's Avatar
    Install google keyboard. You needn't use it, just install it.
    Mike1117 likes this.
    06-10-2015 06:46 PM
  11. Mike1117's Avatar
    Had to reboot my phone to get it to work, but now it does. Thank you!
    06-11-2015 02:50 PM
  12. recDNA's Avatar
    Yes, I forgot that step. Before lollypop it didn't work at all on VZW Note 3 no matter what you did. It annoys me it doesn't work with sammy email app.
    06-12-2015 09:54 AM
  13. Rahul_Does's Avatar
    Even last update killed it in my Moto G3. It is so frustrating! Cannot find an answer!
    06-25-2016 02:42 AM
  14. recDNA's Avatar
    Wow. That sucks. It is a great feature. One more reason to hold on to my Note 3.
    Rahul_Does likes this.
    06-25-2016 08:02 AM
  1. Problem downloading themes in Galaxy s6 Theme Store
    By viaroyals in forum Ask a Question
    Last Post: 07-06-2016, 04:26 AM
  2. Replies: 1
    Last Post: 06-05-2015, 06:54 PM
  3. Replies: 1
    Last Post: 06-05-2015, 06:27 PM
  4. I can't delete emails in moto g, they keep reappearing.
    Last Post: 06-05-2015, 11:21 AM
  5. Itunes Playlist in Play Music with Doubletwist?
    Last Post: 06-05-2015, 10:48 AM
