1. AC Question's Avatar
    I exchanged my s3 for s6 edge and transfered sim card. I now only get 3g when using phone away from home or other wifi point. Is it because i swapped sim card or is there a problem with the phone.
    Jacky
    06-13-2015 04:15 AM
  2. itguyjax8430's Avatar
    Jacky
    Welcome to Android Central!
    Try going in to your settings, mobile networks, network mode, depending on where you are select LTE/WCDMA/GSM (auto connet). That should fix you up if that is the issue.
    06-15-2015 09:11 AM
  1. Replies: 2
    Last Post: 06-19-2015, 02:37 AM
  2. How do I tranafer my synced photos from facebook to my phone
    Last Post: 06-15-2015, 09:08 AM
  3. How do I tranafer my synced photos from facebook to my phone
    Last Post: 06-15-2015, 09:06 AM
  4. Fingerprint Scanner not working?
    Last Post: 06-15-2015, 09:03 AM
  5. My fingerprint scanner is not working, how can I fix it?
    By AC Question in forum HTC One Max
    Last Post: 06-15-2015, 09:02 AM
