1. AC Question's Avatar
    My Mobile Data quick launch icon disappeared into oblivion on the 11th June 2015 in Macau. I am Malaysian. Since this could be a global problem looking at the postings here, I guess Samsung has to do something before important icons disappear again.
    This problem of icons disappearing could be prevalent in 5.0.2. or maybe specific to Samsung Galaxy S6 only.
    PK
    06-18-2015 10:34 AM
  2. Javier P's Avatar
    It seems that Samsung released a fix for that. Check this other thread.
    I had the same issue with my S6 Edge.
    This is how I solved the problem:
    Go to "Galaxy Apps", find "QuickPanel Restore", install it and click Restore.
    Problem solved!
    http://forums.androidcentral.com/sho...d.php?t=539944
    06-18-2015 10:48 AM
  1. Amazon - S6 Active
    By ryjb in forum Samsung Galaxy S6 active
    Last Post: 06-18-2015, 11:43 PM
  2. My Galaxy S5 is in the safe mode and I can't get it out of it?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 06-18-2015, 11:22 AM
  3. Galaxy S6 clear view case
    By bearwillis in forum Samsung Galaxy S6
    Last Post: 06-18-2015, 10:20 AM
  4. Replies: 0
    Last Post: 06-18-2015, 10:15 AM
  5. Replies: 0
    Last Post: 06-18-2015, 10:11 AM
