How can I get my Smart Lock setting working?
A
AC Question
Smart Lock Setting Wont Work
I use a Samsung S6 Edge. I have a fingerprint Lock enabled with the Device Auto Lock set to 5 minutes. I also have Trusted Places (Home & Office) added. I have a trusted Device (bose Headset) added as well. But still my device gets locked automatically after 5 mins even if i am in the trusted place or connected to trusted device.
can you please help me understand why i am facing this issue !
Jun 25, 2015
5
Re: Smart Lock Setting Wont Work
That's a Good Catch recDNA. Thanks for brigning that up. i missed to think Through that. However, My office mailbox just mandates me to set any screen lock protection. Does not really have any configuration for screen lock. do you think the app might have this "force screen lock" setting internally ?
Jun 25, 2015
5
Hi All,
I had initially posted this question as a Guest. But then setup a Login for myself. So going forward i will reply from this ID
Thanks,
Sathish
TaRT zKie
Banned
May 25, 2015
71
Maybe you can check your Lock Screen & Security > Secure Lock Settings > Lock Automatically > Then change it.
Jun 25, 2015
5
Hi TaRT zKie,
As i mentioned in the Original post, i already have my automatic Lock set to 5 mins. The question is on, why the screen gets Locked when it is not supposed to :-(
Thanks,
Sathish
Mark_Henson
Active member
Jun 28, 2012
29
I have trusted devices setup as well, and it's kinda iffy, sometimes I can just swipe, but other time I have to do the fingerprint as well.
recDNA
8,692
112
63
It times out after 4 hours. I'm not sure work email could disable it. Just a possibility. There is no trick to setting it up. Mine works perfectly with my gear 2 or at home.
Jun 25, 2015
5
Yes Mark i end up doing the same many a times. Just swipe wont work. I will have to do the fingerprint as well. Not sure if this is an issue that i need to report to T-Mobile or this is how it designed to work !
Mark_Henson
Active member
Jun 28, 2012
29
No, I don't, I have a company phone, so I don't need it on my personal phone. I don't believe it's carrier specific as I'm on Sprint.
Cy3berOdyssey
