Do you use lightflow for led notifications? I am curious if it works in GS6 Edge, especially the VZW version. What colors do you get? Thanks
I know it is a pain but could you tell me all the colors you can get? It seems like the led gets fewer colors with each new generation of galaxy phones.
There is no phone in which ALL the custom colors work. How about listing 10 easily discernable colors? Light flow lets you produce an almost infinite number of shades. The led of the phone will not actually show all those colors discernably. Like white in light flow often looks bluish on the led.There is no way to list all of the colors, there are too many!! You can even make your own colors. Download the free version to try first, if you really want to know what colors it has.
What's the matter you too lazy to install it yourself and find out? Sheesh!There is no phone in which ALL the custom colors work. How about listing 10 easily discernable colors? Light flow lets you produce an almost infinite number of shades. The led of the phone will not actually show all those colors discernably. Like white in light flow often looks bluish on the led.
My decision whether to purchase an edge is based on this question.What's the matter you too lazy to install it yourself and find out? Sheesh!
I can't install lightflow and set up notifications at my local store. Perhaps someone else will help me.Go to your your local carrier and play with a display phone. #ProblemSolved
Would you tell me if your edge lighting works while you are using lightflow? Mine won't work. Do you use the stock text messaging app, or is there another one you are using. Thanks in advance for your relply!
I cannot get either lighmanager or lightflow to work. I have a permanent blue light! For every notification it is blue, blue, blue! Help me! What am I doing wrong?
