1. Nsh222's Avatar
    Hi, Do not disturb feature in my s6 edge is not blocking calls like the previous Blocking mode in Samsung devices. It just mutes the device and incoming calls.
    Is there any other way to block all calls like the previous blocking mode.
    Please help.
    Thank you.
    06-30-2015 08:28 AM
  2. boogas8's Avatar
    When it's on did you go to the settings and make sure that there calls are not listed as am exception?
    Sent from my Galaxy S6 Edge via the Uncarrier
    06-30-2015 09:49 AM
  3. Nsh222's Avatar
    I checked, Calls are Not listed in exceptions.
    Do not disturb states that it just mutes the incoming call.
    So this means no more blocking all call mode in S6 edge????
    Thank you.
    06-30-2015 10:08 AM
  4. Nsh222's Avatar
    Please reply anyone,as it is very important. Thank you
    06-30-2015 04:52 PM
  1. Replies: 4
    Last Post: 07-02-2015, 10:17 AM
  2. How do I eliminate a repetitive "sending failed" start-up message?
    By yukon_cornelious in forum Ask a Question
    Last Post: 06-30-2015, 07:53 AM
  3. Replies: 0
    Last Post: 06-30-2015, 07:32 AM
  4. How do I back up my new Galaxy 6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 06-30-2015, 07:24 AM
  5. System clock and alarm not working suddenly
    By KPO in forum Ask a Question
    Last Post: 06-30-2015, 06:39 AM
