1. rjgula52's Avatar
    Can anyone list a step by step information on the process to Root my Samsung Galaxy S6 Edge smartphone?
    Thanks
    06-30-2015 02:07 PM
  2. devoxxx's Avatar
    What Model EDGE do you have i just recently rooted my EDGE on Sprint running Android 5.1.1
    08-19-2015 01:34 PM
  3. buterakisses's Avatar
    how do we root a galaxy s6 edge 5..11
    08-29-2015 07:53 PM
  4. neebi007's Avatar
    Plenty of information online READ.
    Keep in mind one thing which ever procedure you take make sure it does not trip your knox or you will lose warranty, samsung pay and fingerprint.
    Over at xda there is a way to root any s6 or edge without triping knox.
    Sent from my SM-G925F using Tapatalk
    09-25-2015 06:43 AM
  5. neebi007's Avatar
    [HOWTO][GUIDE] Flash anything on G925F without tripping Knox - http://forum.xda-developers.com/show....php?t=3158606
    09-25-2015 09:06 AM
  6. KMV15's Avatar
    It worked..
    11-03-2015 04:51 PM
  7. Sakari Sainio's Avatar
    And fingerprint is working??
    11-06-2015 09:29 AM
  8. DFX's Avatar
    I'm under custom rom 5.1.1
    fingerprint is working perfectly.
    12-27-2015 08:01 PM
  9. Randy 1's Avatar
    Hi everyone, problem is I have tried the root process that XDA has on there site and every time I try it get a message about bootloader won't allow root. I have no idea what's going on with my S 6 edge. Mine is paid for and it's out of warranty so I'm not worried about tripping knox, any ideas?
    S 6 Edge
    925A
    5.1.1
    kernel 3.10.61 5947275
    Jan.29,kst. 2016
    LMY47X G925AUCU3B0J9
    KeiEss likes this.
    04-04-2016 10:43 AM
  10. KeiEss's Avatar
    bump
    06-15-2016 12:25 PM
  11. baknblack's Avatar
    You have to unlock the bootloader by enabling the developer options. About phone, tap build number 7 times the check bootloader unlock and USB debugging.
    06-30-2016 01:01 PM
  12. bansdha's Avatar
    how to root sm-g925i plz help me
    08-01-2016 11:26 AM
  1. Replies: 1
    Last Post: 12-01-2015, 06:07 PM
  2. Why is my smartphone getting overheat and disconnecting from the network frequently?
    By Sivaram Prasad Bhavisetti in forum Legacy Android & Other OS's
    Last Post: 06-30-2015, 06:50 PM
  3. Replies: 1
    Last Post: 06-30-2015, 03:49 PM
  4. How do I enable 4G LTE on Nexus 4?
    By adam5555 in forum Ask a Question
    Last Post: 06-30-2015, 01:40 PM
