08-19-2015 05:55 PM
29 12
tools
  1. thegame161's Avatar
    What's your average screen time and total?
    Anybody use the gear with it?
    07-06-2015 02:16 AM
  2. oscarnyc's Avatar
    16 hours on, 4 hours screen is typical which ends at around 15-20% battery. Don't use a smartwatch of any kind
    Solomon Taiwo1 likes this.
    07-06-2015 07:56 AM
  3. Fred Wilson2's Avatar
    I'll have to check my total on time again today, I'm charging mine now, however my screen time was 4 1/2 hours with 46% battery left.
    Fred
    07-06-2015 09:19 AM
  4. 1dtb's Avatar
    Great battery life at home turf, but when I go on the road via airports in different cities well let me say don't forget your charger or an outboard battery!!!
    pbasister likes this.
    07-06-2015 01:48 PM
  5. engvit's Avatar
    I have to charge it every day, but i do admit i use it quite often.
    07-07-2015 11:42 AM
  6. RN50's Avatar
    Easily get anything between 4-6 hours SOT depending on what I'm doing. Phones usually on for around 14-15 hours before I put it on charge at bedtime.
    07-07-2015 12:06 PM
  7. c1971ace's Avatar
    Sucks. Period.
    07-07-2015 03:12 PM
  8. Derek Danforth's Avatar
    Mine lasts all day with moderate usage. Heavy usage requires a charge at about 5pm.
    07-07-2015 04:03 PM
  9. thegame161's Avatar
    53% with 16 hours total so far...1 hour 20 mins screen time
    Sent from my SM-G925F using Tapatalk
    07-08-2015 07:21 AM
  10. DSMpowerhousegroup's Avatar
    Average 4 to 5 hours screen on time with my best being over 6 hours. Average 15+hours on a charge. Best I've owned.
    07-08-2015 09:55 AM
  11. mountainman's Avatar
    Here is mine tonight
    Attached Thumbnails How is your battery life like on your edge?-1436413322417.jpg
    07-08-2015 10:42 PM
  12. neumann45's Avatar
    yes man, i thing
    dont use smartwatch
    07-09-2015 01:51 AM
  13. Leoncio Zamora's Avatar
    Mine is 20-24 hours total usage with 6.5 to 8.5sot
    07-15-2015 02:37 PM
  14. LOLWOWJason's Avatar
    10 hours on, 3.5 hours screen and mine ends at 34% battery.
    07-15-2015 10:40 PM
  15. giodomin91's Avatar
    Mine has been pretty abysmal for the past two weeks or so. It won't get me through a nine hour work day with barely any use. I tried every suggestion
    Attached Thumbnails How is your battery life like on your edge?-1437023125638.jpg   How is your battery life like on your edge?-1437023134356.jpg   How is your battery life like on your edge?-1437023141827.jpg   How is your battery life like on your edge?-1437023150328.jpg
    07-16-2015 12:05 AM
  16. Fred Wilson2's Avatar
    You must be doing constant Instagram syncing. That's where, by far, most of your usage is.
    I have Instagram, but I only log in when I want to look at something or upload.
    It appears to be a real battery user, especially if you're syncing constantly.
    Fred
    07-16-2015 12:33 AM
  17. jcdub's Avatar
    Sucks. Period.
    +1!
    07-16-2015 02:17 AM
  18. giodomin91's Avatar
    Fred
    That's the issue though. I'm not on Instagram all that much. It just seems to always be running in the background. And if its not Instagram, then its chrome doing the same drain.
    07-16-2015 02:19 AM
  19. yyy999deba's Avatar
    I charger it every day.
    07-16-2015 02:46 AM
  20. Fred Wilson2's Avatar
    You have to log out of Instagram when you're not using it.
    I always log out when I'm not using it and on the days that I don't use it I show no CPU or battery use from it at all.
    And I never use Chrome. If Chrome is showing battery usage when you have not used Chrome, then you have left it open with a website running in the background.
    Fred
    07-16-2015 10:03 AM
  21. TheGeekNextDoor's Avatar
    Battery life has sucked even after I went to drastic measures to make it good. I noticed that if I move about town, the phone consumes enormous amounts of battery. It gets hot and doesn't seem to show what is really using the battery. I don't understand this. I'm sure it is google now, but I've turned that off before and it didn't seem to help. I've even turned of location services and it didn't help much.
    Most recently I have swapped out the launcher and now run Nova. With the samsung launcher, it was taking 2-5 seconds for the camera to launch from the double tap of the home button. With Nova, it is as fast as can be.
    I never believed just how awful samsung's launcher could be, but it lives up to the hype of being horrible in just about every way.
    I'll let you know how it goes ditching TouchWiz, but so far so good. I never used any of the touchwiz features anyways, so they really weren't needed. The screen is too small to do split screen or floating windows. TouchWiz must consume every ounce of memory in the phone!
    07-16-2015 10:28 AM
  22. jinzen's Avatar
    Battery life is acceptable on mine. I disabled as much as I could and it lasts about as long as my iPhone 6.
    07-16-2015 12:15 PM
  23. Leoncio Zamora's Avatar
    Mine has been great since day one I followed all the battery saving tips on another one of these forums. This is a replacement to my first device was the same with battery, my auto rotate was the issue with my device a 64gb white s6 edge good thing that happened cause att only had 128gb white edges so that's what I got at a 64gb price point and the battery is awesome along with a monster benchmark score.
    Attached Thumbnails How is your battery life like on your edge?-2120.jpg   How is your battery life like on your edge?-2121.jpg   How is your battery life like on your edge?-2122.jpg   How is your battery life like on your edge?-screenshot_2015-07-15-08-33-16.jpg
    07-18-2015 06:20 PM
  24. Gazella's Avatar
    I don't have numbers but I'm happy with the battery life on mine. It lasts me all day.
    Sent from my Emerald Green S6 Edge
    07-19-2015 05:21 AM
  25. annskrn21's Avatar
    The first until one and half month my battery is okay. One charge/day. Lately my battery drained so fast. My ram works 80% every time even i dont use multi tasking (just one app) do you know what happened to my s6? I updated the last version of samsung push service but it still drain so fast. And my device always hot.
    07-19-2015 10:22 AM
29 12
  1. How can I turn my Google Play Service back on?
    By AC Question in forum Google Play Store
    Last Post: 02-05-2017, 04:38 AM
  2. how can i see the call log which was deleted yesterday
    Last Post: 07-15-2015, 08:25 AM
  3. Is the headphone slot broken or can I fix this?
    Last Post: 07-06-2015, 05:07 AM
  4. Replies: 1
    Last Post: 07-06-2015, 02:14 AM
  5. Replies: 0
    Last Post: 07-06-2015, 02:00 AM
