1. ShaneOsborneUK's Avatar
    As you may already know, the market is full of fake Samsung Accessories.
    I hope you can help me on this one.
    I have purchased a 'geniune' S6 Edge Clear View Cover (Blue/Black).
    This case has an internal magnet which switches off the screen when closed. The problem I have is that you can see this magnet from the front, when the case is closed. Should this be the case or not?
    Thanking you in advance 😕
    07-23-2015 12:06 PM
  2. Scionergy's Avatar
    I have the gold case for my Gold S6 edge and it is the same, you can see the magnet in the bottom left corner of the case - keep in mind that this is a semi-transparent case to allow certain info to show through the closed case - so I think this would be unavoidable with this kind of case.
    07-23-2015 02:00 PM
  3. ShaneOsborneUK's Avatar
    Ah, okay and many thanks. I wanted to check as my previous purchase was a fake and eBay is littered with them. I did call Samsung for advice and they had no advice to give on checking if an item is fake or not, seems silly that they have no advice. My previous was a fake as the magnet (inside) was covered with a sticker and the paint would scrape off like a scratch card.
    Many thanks again for your help.
    07-23-2015 02:40 PM
  1. Verizon black samsung galaxy S6 EDGE 64gb
    By StayFly in forum Marketplace Archive
    Last Post: 09-23-2015, 03:33 PM
  2. S6 Battery DEAD OOB
    By Brighton Line in forum Samsung Galaxy S6
    Last Post: 07-24-2015, 11:08 AM
  3. Samsung Note 5 (and S6 Edge+) Boot Screens (PICS)
    By smooth4lyfe in forum Samsung Galaxy Note 5
    Last Post: 07-23-2015, 11:52 PM
  4. Bought the S6.
    By deadp1xel in forum Samsung Galaxy S6
    Last Post: 07-23-2015, 04:25 PM
