1. pvdtrance's Avatar
    Where and how do I find my WPS code for my Samsung G6 edge?
    07-26-2015 10:51 PM
  2. srkmagnus's Avatar
    Welcome to the forums!
    Are you referring to the WiFi networks password? That's what you'll need to connect to the WiFi network - check with the owner of the network for that password.
    If you are trying to connect something to your device, then there should be a prompt that will tell you what code to enter on the other device.
    07-27-2015 01:11 AM
  1. Replies: 12
    Last Post: 07-28-2015, 05:28 PM
  2. How can I recover my pin code on my Samsung Galaxy S5?
    By K KH in forum Samsung Galaxy S5
    Last Post: 07-27-2015, 09:00 AM
  3. Zip code and phone # format?
    By missouriexile in forum LG G4
    Last Post: 07-25-2015, 05:36 PM
  4. Replies: 1
    Last Post: 07-25-2015, 02:15 AM
  5. Replies: 1
    Last Post: 07-24-2015, 11:57 AM
