1. dfb8085's Avatar
    Anybody trying the wireless charging puck from Samsung. So far this thing sucks. Can hardly get the phone in position to charge. I have to continue to wiggle and move it around slightly over and over to find the sweet spot. Then when I get up in the morning its cut off and the phone is maybe at 90% charge. Does using a thin case hinder the charging connection?
    08-15-2015 07:58 PM
  2. Rukbat's Avatar
    1. A case shouldn't hinder charging. (I charge through an Otterbox Defender, and that's not "thin".)
    2., The S6 will charge on a Qi plate, and a 3-1/2" X 6" (about the standard size) Qi plate with a charging light will make it a lot easier.
    08-16-2015 04:00 AM
  3. jonlm's Avatar
    Hi guys I have an S6 edge with a 3M carbon fiber Sticker and a Goopery case on it and have no problem charging the phone overnight, the only thing to be done is to make sure you place the phone correctly over the charger and shut down the vibrations notification. Hope this helps.
    11-19-2015 01:00 PM
  4. GutterGuppy's Avatar
    I have used this charger for 6 months or better but really havent had too many problems with it. Once in awhile my phone receives a notification while charging and the charger flashes blue and starts draining slowly. However today i took the phone off the charger after receiving a notification and the charger was flashing blue and the charger continued to flash blue. Any idea as to why this may have happened or what is causing it? I haven't yet just unplugged the charger as I am watching the Seahawks game< i am sure the turning off and on of the charger should reset it but wondering WHY it happened. Anyone? Thanks in advance
    01-03-2016 05:57 PM
  1. Samsung support is non existent
    By dbarnes2270 in forum Samsung Gear S
    Last Post: 12-06-2015, 10:51 AM
  2. What you think about that Samsung pay
    By cnotes63 in forum Samsung Galaxy Note 4
    Last Post: 09-09-2015, 03:53 PM
  3. import photos from Samsung Note4 to my pc?
    Last Post: 08-16-2015, 04:04 AM
  4. Why are my Samsung Tab 4 close up pictures so blurry?
    By AC Question in forum Samsung Galaxy Tab4 10.1
    Last Post: 08-16-2015, 04:02 AM
  5. Replies: 2
    Last Post: 08-16-2015, 03:53 AM
