1. AC Question's Avatar
    when someone texts a pic, shows download button, I click it . displays that it's downloading pic, then it stops. Then it displays again download button. Where is the pic? Thanks
    08-19-2015 04:35 PM
  2. Raina Kim1's Avatar
    When someone sends a picture text message to you, you must have data in order to receive the picture, this is also required for long text messages that says MMS at the bottom. Anyways, if you don't have data or its not turned on, it wont be able to download.
  3. Raina Kim1's Avatar
    08-19-2015 04:56 PM
  4. RN50's Avatar
    You should have an app called My Files. This is where all your downloads are located.
    08-20-2015 11:41 AM
  1. Samsung S6 back to Swipe unlock
    By DLW3555 in forum Samsung Galaxy Note 3
    Last Post: 09-17-2015, 08:40 PM
  2. AT&T Galaxy S5 Lollipop 5.1.1 update, when am I getting it?
    By Carlymac in forum Legacy Android & Other OS's
    Last Post: 08-20-2015, 08:36 PM
  3. Replies: 1
    Last Post: 08-19-2015, 10:55 PM
  4. Why is my Droid Razr hd battery life draining so fast?
    By Divine Amewudo in forum Hardware Hideaway
    Last Post: 08-19-2015, 10:51 PM
  5. Replies: 1
    Last Post: 08-19-2015, 10:49 PM
