1. Abz Koyar's Avatar
    Hi, Im in the UK
    I dont know if anyone else is having this problem, but after I updated my Samsung edge to lollipop 5.1.1 , it seems that the parallax effect or the 3D effect has stopped working. I know that if I hold on the home screen and click the wallpaper settings, I get a little toggle which switches the motion effect on/off. But what ever I do it still makes no difference to the home screen. it still stays the same. Is there something that I am missing or can I downgrade to lollipop 5.0?
    08-23-2015 06:08 PM
  2. Da Sko's Avatar
    Hi Abz,
    It is correct. Since the last lollipop update the parallax 3D effect is gone. This is a bug in lollipop version 5.1.1. There's no fix atm. You can't do a downgrade. Even if you decide to set factory the lollipop version will be 5.1.1. I've contact Samsung 2 weeks ago about this issue and they did answer. The bug is also reported to Android. Hopefully they will work on it. We have to wait. It's not working on my phone either but that's okay. The rest is working properly.
    Regards
    David
    Messala likes this.
    08-24-2015 02:54 AM
  3. Da Sko's Avatar
    Hello Abz,
    Maybe this might be good news for you :
    There is another way to get back the parallax 3D effect.
    Go to your google store and search for "3D parallax background."
    After you install this app, you must search in the settings and activate parallax. There is also a way to set the way how fast icons can move over your screen.
    It works now here on my phone. You can choose a background from the app itself, or you can select your own background wallpaper.
    Good luck. It works great now!
    David
    09-06-2015 08:31 AM
  4. davidwilling's Avatar
    Hi,
    Since you downloaded the 3D Parallax app, has it affected the battery life at all? I ma quite keen to get it but not to the detriment of the battery.
    Thanks.
    09-07-2015 07:07 AM
  5. Da Sko's Avatar
    Hi Davidwilling,
    The 3D background app is working properly and the battery is fine. I see no problems here. I also have more news since today. Today I received a new lollipop update. This time android did a fix. I still have the 3D app on my phone but now the parallax effect on Android is just working again. So maybe be patient until you receive the message for a new update.
    09-07-2015 06:39 PM
  1. Replies: 6
    Last Post: 01-17-2016, 07:14 PM
  2. Replies: 3
    Last Post: 09-08-2015, 03:21 AM
  3. What is this on my screen please
    By Chigirluk in forum Samsung Galaxy S6
    Last Post: 08-24-2015, 10:09 AM
  4. Loving the Edge Plus
    By Paul Guest1 in forum Samsung Galaxy S6 edge+
    Last Post: 08-24-2015, 01:13 AM
  5. Replies: 1
    Last Post: 08-23-2015, 06:30 PM
