1. zdentonz's Avatar
    Not sure how else to title it but having an issue with unlocking my phone. As soon as I unlock it, the screen blanks out as if I locked it and then have to unlock it again. Not sure what the issue is. Could it be CM Locker? This happens almost every single I unlock the phone where I have to unlock it twice. Does anyone else experience this issue or is it a known issue without CM Locker?
    08-25-2015 05:08 PM
  2. Javier P's Avatar
    Have you already tried disabling CM locker? It seems that it's doubling your lock screen. To do this maybe you'll need to uncheck it first from the device administrators list in your security settings.
    08-25-2015 05:18 PM
  3. zdentonz's Avatar
    Javier, I have disabled it and I gave it a day to see if it would still happens; it does. Any other suggestions? Could it be CM locker? Anyone recommend a better lock screen?
    08-27-2015 03:51 PM
  4. Javier P's Avatar
    I just use the stock lock screen. The Smart lock options and notifications work great for me. I would uninstall any CM app that you installed. I've seen many problems in these forums coming from them. Any app that can mess with the lock screen should be listed under device administrators. Do you have more apps on that list?
    08-27-2015 06:42 PM
  1. Considering the unlocked LG G4, need input
    By Shermdiggity in forum LG G4
    Last Post: 09-05-2015, 08:50 PM
  2. 5.1.1 or 6.0 for the G4?
    By DamianP in forum LG G4
    Last Post: 08-27-2015, 09:51 AM
  3. What should Samsung do about the stuck S Pen thing?
    By Phil Nickinson in forum Samsung Galaxy Note 5
    Last Post: 08-25-2015, 08:18 PM
  4. Replies: 1
    Last Post: 08-25-2015, 08:02 PM
  5. Replies: 0
    Last Post: 08-25-2015, 04:32 PM
