Shop Cyber Monday deals at: Amazon | Walmart | Best Buy | Dell | Samsung
  1. AC Question's Avatar
    Samsung s6 edge sees my lg watch r in Bluetooth settings but will not connect, yet in the android wear app it shows the watch as connected. All works well under wifi but just won't stay stable under Bluetooth
    08-27-2015 04:31 PM
  2. mxrider821's Avatar
    Mine works perfectly and I have the exact same setup. I would say restart the watch and pair Bluetooth again. It should work [ATTACH]null[/ATTACH]
    Attached Thumbnails How can I get my Samsung S6 Edge to connect to my LG Watch R using Bluetooth?-8752.jpg
    08-27-2015 09:36 PM
  1. When getting a call, can I have it pick up through Bluetooth?
    By AC Question in forum Samsung Gear S2
    Last Post: 09-02-2015, 03:25 PM
  2. Replies: 1
    Last Post: 08-28-2015, 03:41 PM
  3. Replies: 1
    Last Post: 08-28-2015, 01:45 AM
  4. How do I clear and restart my Android?
    By AC Question in forum Misc. Android Phones
    Last Post: 08-27-2015, 04:27 PM
  5. Can I block incoming calls and only use it for out going calls?
    Last Post: 08-27-2015, 04:11 PM
