1. AC Question's Avatar
    Mobile networks doesn't show up in Connections Settings. But if I go to Edit quick settings the mobile networks tab appears I tick the box but it still doesn't appear in Connections. Any hints on how I might get my sim card connected.
    10-20-2015 05:55 AM
  2. sLithery's Avatar
    You've to drag and drop it and put it to any position in the first two rows.
    10-21-2015 05:44 AM
  3. Edna Alcazar's Avatar
    Happened to my friend also. Do what the other member told you to do and it will work perfectly.
    10-21-2015 07:35 AM
  1. Why won't my battery display past 1% when it has a full charge?
    By AC Question in forum Chargers and Batteries
    Last Post: 12-06-2015, 01:50 AM
  2. Nexus 5 - Why can't I transfer files from my phone to my PC?
    By AC Question in forum Google Nexus 5
    Last Post: 10-24-2015, 06:18 PM
  3. Replies: 0
    Last Post: 10-20-2015, 05:47 AM
  4. Why doesn't my Samsung Galaxy 3 charge with the charger?
    Last Post: 10-20-2015, 04:46 AM
