1. joel margetts's Avatar
    I have a galaxy s6 edge running Android lollipop 5.1.1 and the paralex or 3d effect they call wallpaper motion effect isn't working. I have read that it doesn't work at all on 5.1.1 but all so there has been an update that makes it work. It definitely isn't working on my s6 edge. Does anybody know what's happening please. Is there a fix or anything I. can do. Please help.
    10-29-2015 07:38 PM
  2. paridge's Avatar
    On AT&T phones, you have an option to turn it on/off when you go to choose your wallpaper, even if you do so from the gallery.
    10-31-2015 04:09 AM
  3. joel margetts's Avatar
    hi, i have a toggle to turn it on and off when you go into wallpapers. no luck with that though. cheers any way.
    11-01-2015 11:16 AM
  4. Jon Spurgeon's Avatar
    I have the same issue, toddle option, but does not work either way
    11-16-2015 04:44 PM
  5. Nich Dagostino's Avatar
    change your theme back to default and then look at your wallpaper, boom problem solved Samsung edge users
    12-07-2015 08:45 PM
  6. roy_geejay's Avatar
    Please check my post on this section. there is detailed information regarding this issue.
    Posted by the Gold Platinum Galaxy S6 Edge via the Android Central App
    12-08-2015 04:27 AM
  1. Turbo on ATT and default voicemail
    By CraesheTurbo in forum Motorola Droid Turbo
    Last Post: 12-10-2015, 05:16 PM
  2. Why isn't Samsung Pay downloading?
    By kareem jones in forum Samsung Galaxy Note 5
    Last Post: 10-31-2015, 08:56 AM
  3. Why are my apps not showing up?
    Last Post: 10-30-2015, 08:29 PM
  4. Replies: 1
    Last Post: 10-29-2015, 09:02 PM
  5. Why don't my flashlight and camera flash work, it did yesterday?
    Last Post: 10-29-2015, 07:43 PM
